Standard coach bolt or external for deck
Discussion in 'Landscaping and Outdoors' started by Simurgh, Oct 28, 2017.
  1. Simurgh
    Simurgh New Member
    I am in the planning/ cost estimation for decking in our back garden.
    As the title says the first question is can I use non external coach bolts? Is it best to use external ones?
    I have never noticed any in use that are external coach bolts, they always seem to be the standard steel ones.
    A bit of info.
    I fist looked a a retaining wall but the garden in nearly 9 meters wide. the foundation and concrete blocks were near the £1000 mark without mortar mix or the surface material. So I am now looking at a deck.
    At the moment the grass is steep and uneven, so I plan on removing some of the soil to lower it to a more even slope.
    I was going to attach the deck to the concrete, however when I looked at it the concrete is not very thick and is resting on soil I think. I will dig down and investigate when closer to forming the foundations.
    A few additional questions.
    Will I need noggins or will 600mm space be ok without them?
    There is a public sewer running down the middle (red yellow box is access pannel) so will not be able to support it in the middle.
    I read (and can no longer find where) I read it to have a double frame. Is the best option? Does it make the frame stronger?
    Your opinion and results for post in concrete or anchor in concrete post on anchor? I have read different articles recommending different approach. Every time I do I keep thinking that my plan is wrong.
    Thank you for reading so far and I appreciate and information you can give, weather you answer a question or simply give your advise.
    I have added some images from Sketchup, I have not been able to attach the Sketchup file.
