Got a leaking stopcock. Not sure if it’s leaking round the gland or the head gear join. (Hopefully got the terminology right there). The compression fittings are dry. My plan is to swap the whole head gear assembly from the new onto the old body. The new and old appear identical externally. Any issues with my plan? I’ll have fresh packing, sealing washers etc that way but avoid wrangling the tap body out from the copper pipe firmly fixed in plaster on both sides. I’ve got a whole new pegler stopcock in hand. I know ptfe in the right place might fix it but Want to fix this tonight without another trip to SF!
Far easier to replace the whole thing with a full bore lever valve. Very rarely can you successfully replace just the guts and find itv works as you have to match manufactures to ensure an exact fit on the seating. Good luck if you go-ahead as I know from experience how frustrating these simple jobs are.
Phil! Why would you want to replace just the innards?! The water will need to be offski/drained for that task, so why not replace the whole fitting? Or, ball-lever-valve as Dave says.
Point being that IF this works, Phil hasn't had to dig out his pipework from the wall and then make good. Got to be worth a try and he's got the parts to hand to replace the whole stop cock if it doesn't work. I would also recommend a full bore lever valve though however that's not going to happen tonight I suspect.
Jobs a good’n! The fresh head seated in there beautifully and I now have a stop cock that turns fully on and off with no weeping. Was all over in twenty minutes. As you lot discussed, a fresh ball valve would be just grand but this worked perfectly. Though not a plumber I was prepared to slice the pipe and resolder to get the new stopcock body in there if required. I count myself lucky.
Sorry to dissapoint guys. I did drill through a pipe under a floor board a couple weeks back. Seeing as the world didn’t completely end after that I’ve grown a lot more confident plumbing!
