Strange noise in CH pipes ?
Discussion in 'Plumbers' Talk' started by circuitbender, Dec 4, 2019.
  1. circuitbender
    circuitbender Member
    Hi
    Just after some of your thoughts on this puzzle please , I have a strange rattling noise when ch is on , through big bore pipes that send the HW from boiler to rest of house , boiler is ground level, pump is in airing cupboard upstairs. Rattling sound like debris flying around the pipes , there is a vertical run of pipe from gnd level to upstairs.
    A new boiler was fitted a year ago , works well. New pump , new controller Plumber drained out old water and added the additives to comply with the guarantee for the new fix.
    Any ideas what this strange sound could be ?
  2. kiaora
    kiaora Screwfix Select
    hi
    may be bit of solder running around, if its annoying, flush it out, check it's OK and add more inhibitor
    peter
  3. Hans_25
    Hans_25 Screwfix Select
    Is it the pipe itself rattling? Try pressing against pipes to see if that stops it. Need to narrow it down a bit.
