D daca13 New Member Nov 6, 2024 #1 Anyone know what this is wrapped round our pipes in the loft? Looks like hessian and possibly nylon tights…? Is it safe to remove and replace with foam insulation. Attachments IMG_3784.jpeg 2.2 MB · Views: 8
C Cris 11 Screwfix Select Nov 6, 2024 #2 Seen it many times in older properties just sacking I think, I just cut it off and replace with foam
H HarryL1234 Guest Nov 6, 2024 #3 Are the pipes still connected to your water supply? If they are redundant and there's no water in them, no insulation is required.
D daca13 New Member Nov 6, 2024 #4 HarryL1234 said: Are the pipes still connected to your water supply? If they are redundant and there's no water in them, no insulation is required. Click to expand... Still connected yes, one is hot and the other is cold.
