Stuck screws - Toilet seat
Discussion in 'Screwfix' started by Mark Street, Feb 9, 2024.
Tags:
  1. Mark Street
    Mark Street New Member
    Hi ,
    Any suggestions as to how to remove stuck toilet seat screws , partially stripped unfortunately. Any help much appreciated
  2. DIYDave.
    DIYDave. Screwfix Select
    Any access from underneath the pan to the fixings ?
    Often the bolts rust / corrode, even if stainless steel, can be low grade stainless ‘recipe’ and what with damp environment and the odd splash of pish over the years, sieze up
    Usual try WD40 (although recent long threads about this stuff isn’t actually a ‘penetrating oil’) but I’m sure we’ve all used the stuff over the years and our fathers before us and in a large amount of cases, it does actually free up your stuck nuts
    Mark Street and WildCat like this.
  3. koolpc
    koolpc Super Member
    Dynamite...works every time!
    Mark Street and Bazza-spark like this.
  4. RegB
    RegB Active Member
    Is that fixing in porcelain?
  5. Bazza-spark
    Bazza-spark Screwfix Select
    Was starting to think you'd given that up :D
    Mark Street and koolpc like this.
  6. BuildingMad
    BuildingMad Well-Known Member
    If all else fails.
    Very slowly drill with 'M35 Cobalt Step Drill Bit 4-12mm' & the head should pop off.
    May have to stop it from turning by holding butterfly nut underside with grips, but avoid any tightening up.
    Usually expensive; 'Temu' have them for £3.59, but add other items for minimum order of £10 & free delivery in about 14 days
    Mark Street likes this.
  7. billysloke
    billysloke Active Member
    Sounds like he'd be better off getting one from the middle of Lidl on the 18th
  8. Mark Street
    Hi
    Unfortunately yes
    Mark
  9. DBCDIY
    DBCDIY Screwfix Select
    As per BuildingMad.Drill the head off the bolt. Given that porcelain holes are normally 'roomy' it should just fall straight through...
  10. RegB
    RegB Active Member
    When you say "partially stripped", do you mean the threads have stripped and you can't unscrew them because they're going around inside the nit, or that the screw head has been, erm, screwed?
    In any case, get some water on it, maybe wrap a sopping wet rag around it with a hole in so that the metal pokes through, and use a Dremmel-type tool to cut it off (through the screw head and bracket). take care that the metal remains wet and cool and protect your china from flying sparks, which are likely to fuse themselves into the glaze, at least if they're like angle grinder sparks they are. I suppose you could use an ordinary angle grinder with a thin cut-off blade, but you would have to be really rather careful of cutting into the porcelaine.
    If you mean the screw head's a problm, you might be able to cut a slot in it, using a part worn mini Dremmel-type disc, and use an ordinary screwdriver.
