Stud wall brick fixings
Discussion in 'Builders' Talk' started by jamime, Jun 11, 2021.
  1. jamime
    jamime Member
    Previous owners knocked through wall downstairs and now I want to board it over.
    I'm building stud wall, bricks are approx 11cm wide with lintel above, single skin. What fixings should I use?
    I was looking at Rawlplug concrete screwbolts or masonry bolts but unsure on what size is required, timber is 38mm thick.
    Wall will have radiator on each side.
    House is 1930's
    Many thanks
  2. jamime
    jamime Member
    They only added a double doorway. They didn't remove the full wall. It has a concrete lintel.
