Sub main earthing
Discussion in 'Electricians' Talk' started by Shippers, Jul 21, 2021 at 6:51 PM.
  1. Shippers
    Shippers New Member
    Hi
    How do I terminate a 25 mm core from a 6493x, acting as the incoming earth from a switch fuse, into a consumer unit whose earth bar only has 16mm terminals.
    TIA
    Shippers
  2. Jimbo
    Jimbo Screwfix Select
  3. Ind spark
    Ind spark Active Member
    Google reducing lug.
    I'd put you a link up if I knew how :oops:
  4. nigel willson
    nigel willson Screwfix Select
  5. Bob Rathbone
    Bob Rathbone Screwfix Select
    Assuming that the CCU is metal, just crimp a lug on the cable, drill a hole in the metal CCU, clean off the paint and bolt the lug to the metal CCU.
  6. jayktee
    jayktee New Member
    I had the same problem a couple of weeks ago, I split the seven strands 3 and 4 between two adjacent 16mm holes, I was considering removing the earth bar and drilling it out for the 25mm core but thought that there may not be enough meat left.
    The Happy Builder likes this.
