Suitable for sealing interior uPVC windows ?
Discussion in 'Builders' Talk' started by DG123, Oct 4, 2020.
  1. DG123
    DG123 New Member
    Hi all,
    Sealing a huge interior window gap, pvc frame against plaster.
    Neither sealants I have mention upvc as explicitly suitable. Will they be OK or what else should I buy?
    Thanks !
  2. Jord86
    Jord86 Screwfix Select
    Expanding foam it first, let it go off for a couple of hours then cut it flush or slightly beneath then use the frame sealant over the top as you can paint over it later.
