Suitable for the task?
Discussion in 'Builders' Talk' started by candoabitofmoststuff, Jul 8, 2020.
Tags:
  1. candoabitofmoststuff
  2. nigel willson
    nigel willson Screwfix Select
    You don’t glue down . Felt nails
  3. candoabitofmoststuff
    I know you do normally.... but it's called "Roof felt adhesive", so presumeable it's suitable for roof felt, (on a s... My question was really about whether or not it would be suitable on OSB.
    Cando
  4. Hans_25
    Hans_25 Screwfix Select
    I guess it would work, but why would you want to (instead of nails)?
  5. DIYDave.
    DIYDave. Screwfix Select
    When the felt fails in a few years time ..... and it will, and you need to strip the roof to lay new felt, will this adhesive make this process difficult / impossible / ?
    I’ve never used it but have used a similar product in the Black Jack range from Everbuild. This was for a temporary patch repair to a felt garage roof
    Product in link says it’s for asphalt, metal, concrete, no mention of timber but can’t see why it won’t stick to OSB
    Most companies have a tech help line you can call so maybe get the definitive answer from the ‘horses mouth’ .... so to speak
    Have you read the full product detail leaflets available online ? Maybe the answer is contained there ?
  6. candoabitofmoststuff
    I'll have a think about it all.
    Thanks all.
    Cando
