Summerhouse insulation
Discussion in 'Builders' Talk' started by scojototo, Oct 8, 2019.
  1. scojototo
    scojototo New Member
    Hi guys, looking to insulate my summerhouse, i have 50mm rigid to go in between the frame which are 70mm, also have a vapour barrier and plasterboard to finish it off,just not sure what way it all goes on and where to put the air gap. any help would be much appreciated. thanks
  2. b4xtr
    b4xtr Active Member
    Air gap on outside, insulate then vapour barrier then PB, same as if doing a roof
