Surface Mounted Cooker Outlet Plate
Discussion in 'Electricians' Talk' started by ArchStanton, Oct 29, 2021.
  1. ArchStanton
    ArchStanton New Member
    I'm about to connect up a cooker, but the Cooker Outlet Plate is going to need to be surface mounted as it's an old house with very solid walls.
    All the 45A cooker outlet plates shown on the website here seem to have the 2 fascia screw holes lower down than half way - but all the surface mounted 47 mm back boxes I can find seem to have the screw holes dead on the centre line.
    Any suggestions would be much appreciated.
  2. sparky steve
    sparky steve Screwfix Select
  3. ArchStanton
    Thanks Sparky Steve - that should do it.
    What is it with those ones with the screw holes below the centre line ? What sort of box are they meant for ?
  4. sparky steve
    The holes circled red connect to the back box. Holes circled in yellow, are for the faceplate screws.
  5. ArchStanton
    Many thanks Steve - that all makes sense now !
    sparky steve likes this.
