tail lift van security
Discussion in 'Just Talk' started by woodburner, Nov 10, 2009.
  1. woodburner
    woodburner New Member
    Hello,
    How secure is the back door of a Luton box van with a tail lift? The one I have rented has an isolation switch in the cab for the tail lift.
    From what I can see it would be easier gaining access through the side of the van!
    Just need some assurance,
    Wb
  2. joinerjohn
    joinerjohn New Member
    Luton vans are fairly secure woody. More secure than the 7.5tonne curtainsiders I have been driving for work recently. Even the back doors on them didn't have any locking mechanism. Although to be fair , if someone wanted to get into it, a Stanley knife would have been the weapon of choice.
  3. chippie244
    chippie244 Super Member
    It's as secure as any vehicle, if they want to get in they will.
  4. Mr GrimNasty
    Mr GrimNasty Active Member
    tail lift - pf pf pf pfpffffffffffff
  5. woodburner
    How will they get in - through the sides?
    If the tail lift is up and isolated in the cabin it looks as if it would be a hard and long job breaking into the cargo compartment.
    Wb
  6. chippie244
    Break cab side window, switch the tail lift on, lower tail lift. simples :)
  7. woodburner
    Thanks Chippie,
    That's fine. You need an ignition key and code to activate this tail-lift.
    I am being challenged about the vulnerability of the tail lift being an easy point of entry. People are concerned theives will break in to see if anything is inside even though it is empty.
    I keep on looking at it and wondering how you can get in that way without an angle grinder.
    Everyone I have spoken to has said that going through the sides would be the easiest way.
    Wb
  8. Ú¶
    Ú¶ New Member
    I usually enter via the back end.
  9. That's a maurice gagg gogg.
  10. Ú¶
    Ú¶ New Member
    [Edited by: admin]
  11. chippie244
    "That's fine. You need an ignition key and code to activate this tail-lift"
    Not seen that before!
    "I am being challenged about the vulnerability of the tail lift being an easy point of entry."
    Who by?
    "People are concerned theives will break in to see if anything is inside even though it is empty."
    Which people?
    WTF are you keeping in this van that you're so worried about?
  12. woodburner
    Nothing. The van is loaded with furniture driven 5 miles and unloaded. The people I am doing the job for who have rented the van are worried that people will break in when it is parked up at night just to see if there is anything inside that is worth nicking.
    I just can't seem to pacify them.
    Anyway enough said about this topic
    Wb
  13. chippie244
    Next time tell them to pay the little bit extra to protect their excess and then it doesn't matter :)
  14. Mr GrimNasty
    Can't they park it up against a wall or something?
  15. chippie244
    Don't work for nutters.
  16. Mr GrimNasty
    Can't avoid it, I work for myself.
