Tanking on skimmed plaster?
Discussion in 'Tilers' Talk' started by Galaxy99, Aug 26, 2018.
  1. Galaxy99
    Galaxy99 New Member
    Hi everyone
    I’m in the process of installing a new bathroom, with a shower cubicle in one corner. All the walls have been skimmed onto fireline plasterboard.
    Is it still possible to tank the shower area on top of the new skimmed plaster? Or should I have done it before.
    The full bathroom will be tiled.
    All help will be appreciated.
  2. rogerk101
    rogerk101 Well-Known Member
    If the plaster is sound and likely not to shrink or flake off then no problem ... tank away. I would certainly use tanking matting in all corners and edges. Use the recommended tanking primer, then at least 2 coats of tanking applied with brushstrokes at right angles to each other. Tile when dry.
  3. Galaxy99
    Galaxy99 New Member
    Thanks Rogerk101
    It’s newly been skimmed, when you say flake or shrink. Is this something that is common?
  4. LEH
    LEH Active Member
    Hi, are you aware of the weight limit for tiles on plaster skim?
  5. Galaxy99
    Galaxy99 New Member
    Hi LEH
    No idea, never got into that kind of detail. My other bathroom is fully tiled too, never had issues.
    Are you suggesting it’s best to tile straight onto plasterboard?
  6. LEH
    LEH Active Member
  7. Galaxy99
    Galaxy99 New Member
    Thanks LEH
    That link is great bit of info, and yes I was planning to use porcelain tiles. Reading that link I may now have to consider using pvc t&g aqua boards instead. (I’ve noticed there’s plenty of designs and colours to choose from) it will also take away any risk of water penetrating through the grout on tiles.
    Thanks
  8. rogerk101
    That's why grout sealer was invented. Apply at least two coats, and the grout is effectively waterproof.
