Tap not shutting off easily
Discussion in 'Plumbers' Talk' started by Movieman334, May 18, 2018.
  1. Movieman334
    Movieman334 Member
    Hi,
    I wanted to ask for some help regarding a tap I have in my bathroom. It's become increasingly difficult to close (it does close) but over the years it's become more and more stubborn :)
    I would prefer to avoid replacing it especially if it's something as easy as just changing a washer etc
    Is this an easy fix and if so how would I fix it ?
    Thanks in advance
  2. Devil's Advocate
    Devil's Advocate Well-Known Member
    Photo, please.
    If it's stiff, it won't be the 'washer' but more likely the spiral-thread inside it.
    I've sorted out a few stiff taps, and they are easy to fix - if you can dismantle them in situ (the worst part of the job).
    Photo will help.
  3. Isitreally
    Isitreally Well-Known Member
    Possibly limescale build up within the tap body, a strip down and clean should sort it.
  4. DIYDave.
    DIYDave. Well-Known Member
    Then add plumbers grease or Vaseline to the mechanism - keeps it all nicely lubed up and moving sweetly
    If this doesn’t sort it, then tap valves are worn. Gotta match correct size but easy and inexpensive job to do yourself
    You then literally have new taps so all good :)
  5. Movieman334
    Movieman334 Member
    Ok so to clarify, I should remove tap head and then clean the spiral thread inside the tap add plumbers crease afterwards.
    if this doesn't work i need to replace tap valves.
    Do i need to drain down the system to do this ?
  6. just pumps
    just pumps Active Member
    DIY womble likes this.
  7. Movieman334
    Movieman334 Member
    The just pumps, do i still need to drain down the system to replace these ?
  8. just pumps
    You need to isolate the water to each tap yes, any isolating valves fitted underneath?
  9. Movieman334
    Movieman334 Member
    will have to check i don't think there is though :(
  10. just pumps
    If not then suggest you fit some first then you can turn the water to the rest of the property back on and take your time with the taps. Also suggest you start earlier rather than later in the day to give yourself maximum time. ;)
  11. Movieman334
    Movieman334 Member
    is it easy to fix isolation valves ?
  12. just pumps
    On copper yes not so on plastic for a layman.
  13. Devil's Advocate
    Post a photo, movieman, and we should be able to guide you through it all.
    And silicone grease is probably the best lube to use when reassembling - it won't attack the O rings.
  14. WillyEckerslike
    A plumber's crease is a very different thing - a bit like builder's bum but cleaner. Don't post a photo of that for heaven's sake.
    Devil's Advocate, PhilSo and Heat like this.
  15. Dave does Gas
    Dave does Gas Well-Known Member
    Can someone explain to me what plumbers grease is please, Ive only been in the trade for 45 years and never come across it.
    Ive used graffite grease on gas taps, Ive used copper crest on screws, Ive used silicone grease on parts to be inserted with O rings, Ive used silicone spray on soil fittings. But plumbers grease has passed me by.
  16. Isitreally
    Really. ???
  17. Devil's Advocate
    I wasn't aware of Plumber's Grease either, so looked it up thinking it would be better than silicone grease for this job. And then I read "Not for use on rubber or synthetic O rings..." :eek:
    The last one I did, I actually used nice thick 'Copper Ease' on the spiral thread part, and silicone grease on the rubber o-rings. Smoooooooth, man.
    (Surely Copper Ease wouldn't attack rubber since it's the stuff recommended for use on the backs of brake pads - where it's close to the rubber piston bellows?)
