Taping copper pipe
Discussion in 'Plumbers' Talk' started by Oggy02, May 27, 2021.
  1. Oggy02
    Oggy02 New Member
    Hi
    After a bit of advise, if anyone can help please. Just had a plumber put some copper pipes in. Some for water and some for gas. The pipes are going behind plaster boards, which will be fixed in place with dot and dab. He has taped the pipes with duct tape to protect the pipes, but the tape doesn't completely cover the pipes in places. In some areas it is damaged, which has exposed the copper. Not sure how concerned I should be. Was especially concerned with the gas pipe. This has exposed copper and it has been clamped to the wall with straps causing it to bend in places as the wall is not even.
    What are peoples thoughts on this.
    Thanks
  2. BiancoTheGiraffe
    BiancoTheGiraffe Screwfix Select
    Tape?!
    To protect it from what?
  3. I-Man
    I-Man Screwfix Select
    Copper doesn't need duct tape!
  4. Oggy02
    Oggy02 New Member
    What about the plasterboard adhesive eating into the copper?
  5. BiancoTheGiraffe
    It doesn't
  6. pppmacca43
    pppmacca43 Super Member
    Does bonding plaster eat into copper pipes?
