I have just had an underground burst pipe repaired and some new tarmac laid along a one meter width, and 6 meter length where the contractor dug out the old pipe. There was also an area where escaping water from the burst pipe had damaged the old tarmac, due to freezing and thawing several times over. this was approx. 8 sq. meters. The contractor laid the new tarmac up to existing old tarmac. My question is am I wrong to expect them to put a sealant between the old and new tarmac, as standard? This wasn't discussed before hand and wasn't mentioned in the quote, I simply expected this to be standard practise. Am I wrong to expect this?
Sadly I don't think that will happen as the old tarmac is dried out and crumbly and now broken up even more due the the contractors roller. It will now suffer even more as rain will penetrate the joint. Thanks for your reply.
in this case you are right, cracks will remain eventually expand, if this work was under insurance policy you might request re-lay entire surface, if you have employed company for that on your own is no way that you can win, they have done just contracted work- sorry
Yes, that is exactly what I thought but the contractor says that because the old tarmac is "porous" it would be a waste of money. The old tarmac is certainly far more porous now as it's been broken up by the contractors heavy machinery.
