Temporary floor on screed
Discussion in 'Builders' Talk' started by Adam Seed, Sep 1, 2018.
Tags:
  1. Adam Seed
    Adam Seed New Member
    Hi all,
    Just had a new 65mm 4-1 with fibre screed laid on top of UFH through the downstairs of our house. We need to live with it for a while before we put the final floor down and I'm after advise on the best thing to avoid the dust that comes from walking on it.
    I have heard of two options below, which one would be best?
    laying polythene
    Q: can this be any polythene?
    or using a sealer
    Q: When can this be applied to new screed?
  2. DIYDave.
    DIYDave. Screwfix Select
  3. candoabitofmoststuff
    Whatever you use, you need to let the moisture escape, I would have thought?
    So any kind of plastic I suspect is not a good idea.
    I'm afraid I don't have a solution however!
    Cando
  4. Adam Seed
    @DIYDave. Thanks they look decent.
    @candoabitofmoststuff Im no expert but it think the opposit is true. I hear keeping the moisture in makes for a better cure and polythene is used to achieve this. the drying process is not about removing water but a chemical reaction... I think.
    Anyone know about the sealants?
  5. KIAB
    KIAB Super Member
    You can cover with plastic sheet for a week to help it cure,but, the screed will take at least 4-6 weeks to fully dry, maybe longer.
    When the screed is fully dried,give it a coat, maybe two of Everbuild 403 Concrete Hardener & Dustproofer.
    I just lay some 2x1 batten on floor & screw some sheet material like ply, chipboard to it.
    https://www.everbuild.co.uk/product/403-concrete-hardener-dustproofer
  6. candoabitofmoststuff
    In which case I stand corrected!
    Cando
