Terminating 1.5mm lighting cable
Discussion in 'Electricians' Talk' started by pal123, Aug 22, 2020.
  1. pal123
    pal123 Member
    I need to terminate 1 twin and earth lighting cable in my bathroom. This i because I'm planning to remove 2 old 9W IP44 dome lights and reuse 1 of the connections with a IP65 18W new dome light, capping off the old lighting connection. This means capping off one 1.5mm^2 earth, neutral and live cable
    Can I use a spring wire connector cable clamp terminal block (CH2) to do this? I bought this product: https://www.amazon.co.uk/gp/product/B01NGU80LM/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    It was described as a cable clamp.
  2. Bazza
    Bazza Screwfix Select
  3. pal123
    pal123 Member
    What about the Hylec DEKSB-002 DEBOX In-Line Connector Box Junction Box 4 Pole Terminal Block? At ebay: https://www.ebay.co.uk/itm/Hylec-DE...128449?hash=item262564ecc1:g:J6cAAOSwbXddZUzK.
  4. Bazza
    That is the same as the one in my link. Screwfix 99p. Fleabay £2.60 for the same product! Up to you mate.
