Tf1 filter
Discussion in 'Plumbers' Talk' started by Gazowl1975, Oct 9, 2019 at 9:00 PM.
  1. Gazowl1975
    Gazowl1975 Member
    Constantly losing a small amount of pressure on my combi boiler over course of a few days due to the fernox Tf1 filter underneath it leaking ever so slightly are these poor design or has anyone on here got some pointers to seal it more completely? Thanks
  2. Mike83
    Mike83 Well-Known Member
    Poor design.
    Leak all the time.
    KIAB and Gazowl1975 like this.
  3. Gazowl1975
    Gazowl1975 Member
    Change gasket on lid of it maybe?
  4. Mike83
    The lid leaks.
    The iso valves leak.
    Then washers between the filter and iso valves leak.
    The actual body of the filter leaks.
    Gazowl1975 likes this.
  5. Gazowl1975
    Gazowl1975 Member
    It's that poor i think im just gonna leave it alone permanently, hopefully it will seal over time and tbh it only gathered very slight amount of sludge last time I cleaned magnet in it over course of 6 months system water is very clean anyway wish I never bothered with it.
  6. Heat
    Heat Well-Known Member
    You can get a set of seals for it.
  7. Heat
  8. KIAB
    KIAB Well-Known Member
    Fernox TF1 filter,completely naff design.
    Magnaclean Pro 2 or Micro 2 nothing better.:)
  9. Mike83
    Every time I touch one it leaks
    Gazowl1975 and KIAB like this.
  10. Gazowl1975
    Gazowl1975 Member
    Mike it's going off topic but we spoke about the F64 problem I was having on my vaillant combi boiler, after fitting the new pcb is it a case of just power the boiler back on and carry on or is there any checks needed (combustion) fan gas valve etc thanks?
  11. Gazowl1975
    Gazowl1975 Member
    Seem poor yes thanks
  12. Mike83
    It’s simply just changing the pcb.
    Nothing else needs done.
    just changing the pcb won’t affect anything else.
  13. Gazowl1975
    Gazowl1975 Member
    I'm just gonna let dirty water seal it over time and leave it well alone it's not bad but obviously any little let by boiler pressure goes down I'm sick of it. And to be honest magnet collected very little sludge in course of around six months thanks mate
  14. Heat
    Fairly easy to replace the seals. Really just the top lid ‘O’ ring is the usual cause.
  15. Gazowl1975
    Gazowl1975 Member
    Why what's best budget filter out there? Thanks
