C
chippie244
Guest
Are you a scientist?Now there's a statement you couldn't possibly know to be true.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I am a mind reader
You are welcome to do thatI voted remain, however “Leave” Should mean Leave.
Nobody from China or Russia for that matter pays me.
Nor me. How do you feel about vaccination?
Honestly. Some of you will trust years of expertise in your own field (and rightly too) and yet with climate change you trust a few tin foil hat wearers on Facebook rather than 99% of climate change scientists. Amazing.
How do you mean.?
In a bilderberg kind of way. ?
Only we dont trust our own experts, I'm of the opinion that the IET write a load of ******** every year for simply no other reason than extracting money from hard working people.
Yes but I’m guessing that’s your field of expertise so you are commenting from an informed point of view. Have you acquired several years of post-doctoral research experience in the field of climate change?
Errrr. Yes. Ice cores supply this.No point in showing a graph from the 60s, how about one from the time the last ice age ended
Great! So you accept that the climate can change. Presumably you also accept it's through physical and chemical processes - i.e. it's not magic or the gods.how about one from the time the last ice age ended, something melted all the ice and it wasn't a factory pumping out CO2 back then was it?
Looking at the nice graph you supplied with that post, you can also see that around 350,000 yrs ago the ppm of CO2 rose at roughly the same rate as modern times, and again about 275,000 yrs ago. Could you explain these rises please ?It's also worth noting how slowly nature changes temperatures (compared to us
Of course JJ.Looking at the nice graph you supplied with that post, you can also see that around 350,000 yrs ago the ppm of CO2 rose at roughly the same rate as modern times, and again about 275,000 yrs ago. Could you explain these rises please ?
Yes. Carbon dioxide doesn't have to be man made. It's a simple molecule.Yea Einstein, according to your graph Co2 has fluctuated all over then show for the last 800,000 years, something made it do it and it certainly wasn't man made, its high at the present time if your graph is in any way accurate but why so different this time, why is it man made this time round and why isn't it more severe than before we were industrialised? After all 800,000 years ago we had warm, then we had an ice age and then it all melted again and got hot enough to grow grapes in Newcastle. Its supposedly far worse this time round but all we get is a bit of wind and rain.
The axis of both x and y seem to be evenly spaced out both in years and ppm of CO2, so I'd rethink the illusory bit. The approximate years I refer to both show a steep change, comparable with today's changes. I'd just like some sort of explanation for the comparable rises ( which could not be man made)Of course JJ.
The rate of change is illusory because of the scale of the x axis.
