Thermostat wiring help
Discussion in 'Electricians' Talk' started by Dant88, Nov 30, 2020.
  1. Dant88
    Dant88 New Member
    Hi, my old room thermostat has broken, and I’m struggling to rewire a new one in, the original was wired like this 5A903DB6-036E-4DFA-8B57-C3EA984999E9.jpeg The new one wires up like this
    05A2D972-A3B7-4057-BD75-6EF5A9B5C22A.jpeg Can somebody please tell me which wire goes where? I thought it would be an easy swap and Im without heating and too skint to call someone out until next week
    Thanks
  2. spirits are real 2016
    spirits are real 2016 Screwfix Select
    Yes brown goes to com, which is live.
    Terminal number 3 goes to terminal NO
    with the neutral wire which is grey put it in a terminal block if you have one and some tape round it and put it to one side its not needed in your new thermostat..
    Dont forget to turn power off to boiler whilst you are doing the work..
  3. Dant88
    Dant88 New Member
    Thank you, do I put the green and yellow wire in a terminal block too?
  4. spirits are real 2016
    Yes if there is room to put it if not just tuck it out of the way like it is now.. dont put it in with the neutral wire..
  5. spirits are real 2016
    If there is a earth terminal with your new thermostat connect it to that if not just tuck it out the way..
  6. Dant88
    Dant88 New Member
    Thanks for your help
  7. spirits are real 2016
    Has it worked..
  8. Dant88
    Dant88 New Member
    Yes thanks for your help it’s not Baltic in here now
