Thermostatic mixer taps
Discussion in 'Plumbers' Talk' started by Ashbou10, Mar 25, 2020.
  1. Ashbou10
    Ashbou10 New Member
    Hey, is there a certain setup for thermostatic shower mixer. Can i just swap a manual mixer for a thermostatic one. Hot water comes from hot water tank in airing cupboard and cold water comes from tank in loft. thanks
  2. Heat
    Heat Well-Known Member
    Yes, just basically as you said, - you can change over just by connecting to pipes.
    Just be careful to ensure the hot and cold are to correct sides and that the mixer type suits low pressure because your system is from gravity.
  3. Ashbou10
    Ashbou10 New Member
    Perfect thankyou
