Thoughts on shower cabins
Discussion in 'Plumbers' Talk' started by Skyblue1, Jan 17, 2020.
  1. Skyblue1
    Skyblue1 Member
    Has anyone had any experiences with shower cabins? I like that they don't need tiling but wonder if they're reliable. Are they worth the money?
  2. dcox
    dcox Screwfix Select
    Not heard of a shower cabin but I’m curious.
    Skyblue1 likes this.
  3. terrymac
    terrymac Screwfix Select
    If you are referring to shower pods ,they are ok for keeping water within them. But the ones I have fitted were not exactly " stunning looking". Glass panels / door and white plastic wall for the shower to fit onto. Functional ,but not stylish .
  4. Skyblue1
    Skyblue1 Member
    Agree they're not the prettiest. What's the quickest and most practical showers you've come across?
  5. Heat
    Heat Screwfix Select
    Modular shower units they are sometimes called.
    Another option is the one (or two) piece tray and panel type showers.
    All makes sense to me.
    The caravan showers work well
  6. Skyblue1
    Skyblue1 Member
    If it develops a fault/needs servicing, are they difficult to fix?
  7. Heat
    The shower units like you get in caravans can be difficult if shower valve goes faulty as you sometimes have no choice but to replace with identical type.
    On the units that are basically a one piece tray and walls (you then buy a shower door), they will be fine if you install a good quality standard shower valve - preferably an exposed shower valve, so it can be repaired or replaced easily if it gives trouble.
    With ordinary showers with tiled walls you can just remove a few tiles, but above units you cannot
