Threaded rod ceiling fittings?
Discussion in 'Builders' Talk' started by soabar, Nov 14, 2017.
  1. soabar
    soabar Member
    I'm sure I've seen these things, but don't know what they are called & hence can't find them;
    Its a bracket / saddle type affair that's used to support threaded rod from the ceiling, going into a wooden joist, two holes for screw mounting it & a central hole for the rod. The attached image shows the bracket in black.
    What's it called or is it even a thing?
  2. dobbie
    dobbie Well-Known Member
    soabar likes this.
  3. soabar
    soabar Member
    Perfect - thank you!
  4. WillyEckerslike
    Failing that put 'threaded rod ceiling flange' into Google (other search engines are available)
  5. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    I think it's called a 'DelBoy sure-stop threaded bracket' !
    Mr. HandyAndy - Really
  6. leesparkykent
    leesparkykent Well-Known Member
    Ceiling hanger bracket, ceiling saddle bracket, saddle bracket or top hat ceiling bracket.
