Tiger Loop Leak
Discussion in 'Plumbers' Talk' started by Vin, Sep 15, 2018.
  1. Vin
    Vin Active Member
  2. Vin
    Vin Active Member
    My Tiger Loop has started leaking from the top.
    It drips approx once every 5 seconds.
    Can this be repaired or does it need to be replaced?
    Thanks chaps!
  3. KIAB
    KIAB Well-Known Member
  4. Heat
    Heat Well-Known Member
    Replace it. They only have a limited life and are not repairable as I understand.
    Should really be an internal Tigerloop with vent pipe to outside for current regs.
    Expensive though.
    The deairator in the photo is not actually Tigerloop
    I trust the Tigerloop brand.
  5. Vin
    Vin Active Member
    Thanks for the reply’s guys.
    I did take it to pieces to see if I could fix it but there’s a small rubber seal inside which isn’t a standard shape so I gave up.
    I have ordered a new one now which is the same type so I don’t have to change any pipework.
    It is sited in a boiler house but apparently there is an optional extra which allows you to vent externally so I might order that as well
