Tile directly onto bathroom panel?
Discussion in 'Tilers' Talk' started by David Pinkerton, Feb 29, 2020.
  1. David Pinkerton
    David Pinkerton New Member
    Hi,I am planning a bathroom refurb.
    The bathroom currently has mdf style panels on all the walls, they seem to be about 8mm thick and have a few metal strip joints (about one or two on each wall.
    I'm planning on tiling the room. Do you think I could tile directly onto the existing panels?
    Will adhesive stick to the glossy surface?
    Will the metal joints (that sit 1-2mm proud of surface) cause any issues in terms of quality of finish?
  2. Jord86
    Jord86 Screwfix Select
    No, remove them, prime the walls then tile on that.
  3. nigel willson
    nigel willson Screwfix Select
    No definitely not. It’s not designed for that purpose. Do it properly
