Tile lay out - hallway through to kitchen
Discussion in 'Getting Started FAQ' started by Kieron Mitchell, Jul 13, 2020.
  1. Kieron Mitchell
    Kieron Mitchell New Member
    hi all
    I am about to have my downstairs tiled, with large format rectangle tiles (500x1000)
    When you enter the house the hallway flows through to the kitchen on the left, and the dining area & lounge to the right. My question is should i have the tiles centered based on the hallway? or layed either side of the centerline ? or any other suggestions for a lay out. I am going to go with staggered brick pattern
    thanks!
  2. DIYDave.
    DIYDave. Screwfix Select
    It’s a question of trial and error - loose laying a few tiles and seeing what looks best (obviously without tile adhesive)
    You’ve given no dimensions of hall so impossible to picture how the tiles will work out either side at skirting board
    As you’ve suggested, tiles in hall either perfectly centred or whole tile either side of centre line and work outwards but, this really depends on what your left with at wall junction
    As your going with large format tiles, once you start cutting tiles in half, they don’t look so good and less than half should be avoided if possible
    If you have tiles on site, play around with them and see what looks good, also discuss with your tiler
    If he’s a good guy, he will have tiled hundreds of metres and will instantly know what’s going to look best
    Obviously once you start in the hallway, this then determines kitchen, lounge, dining room so again, you really don’t want tile slithers at edges
    ‘Setting out’ is mega important before a single tile is laid
    Good luck
    Kieron Mitchell likes this.
  3. Kieron Mitchell
    Thanks ! appreciate the quick response. Here is a pic attached showing the space either side. The width is 930mm wide, and at the door opening bit its 1800 wide
