Tile trim
Discussion in 'Tilers' Talk' started by Lynda Raftery, Mar 9, 2020.
  1. Lynda Raftery
    Lynda Raftery New Member
    Hi, just a quick question: if my tile is 10mm thick, do I use a 10mm tile trim or 12mm to allow for adhesive?
    Many thanks.
  2. Jitender
    Jitender Screwfix Select
    10mm tile trim refers to the thickness of the tile being used.
    I just put a thinner bed where the trim was in last project.
  3. Lynda Raftery
    Thanks for your reply. So, I should use a 10mm trim then?
  4. Jitender
  5. Lynda Raftery
    Thank you!
