Tiles To Wall
Discussion in 'Builders' Talk' started by Carp Addict, Sep 15, 2006.
  1. Carp Addict
    Carp Addict New Member
    Do you use a notched spreader for fixing tiles to the wall,got alot of building paperwork to do for college?
    Also is a block plan usually drawn to 1:1250 ?
    Cheers
  2. Re tiles, it depends if it's a wet area or not, the size and material of the tiles and the substrate to which they are being attached.
  3. Carp Addict
    Well the ansers are either a masonary saw,smoothing plane or notched spreader.Its a tick box question sheet im doing.
    So would it be a notched spreader?
  4. Fred1959
    Fred1959 New Member
    yes its the notched spreader
  5. Fred1959
    Fred1959 New Member
    and the edge looks something like this
    |¯|<u>|¯|_|¯|_|¯|</u>|¯|
  6. Nutty Oak
    Nutty Oak New Member
    You are having me on aren't you?
    I'd like to see the person who puts up tiles with a plane or saw!!
  7. building control
    building control New Member
    I have seen walls built using a butterknife before now.
  8. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    Bidling a huse, give it up NOW!!!!!
    Mr. HandyAndy - really
  9. Controlled Magic
    Controlled Magic New Member
    Handy Andy.....were you on the turps at 8.45 last night??!
  10. prep it
    prep it New Member
    What's a huse??
  11. Controlled Magic
    So Prep-it, do I understand that you know what bidling is then?
  12. prep it
    prep it New Member
    A bidling is someone who is a novice at auctions and is learning to bid. Hee Hee
  13. Mr. Handyandy
    night??!
    No. Sorry. I was taking the **** out of 'Buidling a House', his spelling error, and age 3 question. If one needs to ask a question like that...........
  14. Mr. Handyandy
