tiling on top of vinyl tiles/floor
Discussion in 'Tilers' Talk' started by house and home, Apr 30, 2009.
  1. house and home
    house and home New Member
    got a bathroom floor to tile, there are some really old vinyl tiles down underneath some lino, im taking the lino up but the vinyl floor tiles look well stuck down (onto floor baords) do they need to come up or? what adhesive should I use for going over the top of them, like I said its a wooden floor with the vinylk tiles on top? cheers
  2. GKU
    GKU New Member
    Do a search on this forum about tiling onto floorboards , there's loads of info on the subject , then come back to us with the same questions
  3. tic tic
    tic tic New Member
    get down 2 B&Q...they will sort u oot with all u need..tiles..addy..grout...:):O
    only kiddin ply over with 18mm prime it...screw it..:)..flexy grout an addy...stay away fae b&pee..:):)O
  4. GKU
    GKU New Member
    But don't you get sick of giving the same old answers day after day though :O
  5. tic tic
    tic tic New Member
    agree with u there GKU does get a bit off a pain in the rectum..when as u say just browsing thro the forum u get all the info u need..:):)..but there is muppets an then some..:x all enjoy ur w/end...
  6. jammyjosh
    jammyjosh New Member
    if you go down to topps tiles you need 2 get bal apd primer to prime the marley tiles then use a 2 part flex adheseve called bal fast flex the superflex grout you will be fine then alot easyer than plying in :)
  7. GKU
    GKU New Member
    :O - Really , and what happens when the floorboards move then , the adhesive and grout may well be "flexible" but it ain't bloody rubber mate , he'll have tiles popping up all over the show , <u>ALWAYS</u> overboard with ply (or the newer alternatives ) - you must have a rigid , solid substrate to tile onto and there is too much individual movement in floor boards , do the job right in the first place and you won't get any comebacks ;)
  8. GKU
    GKU New Member
    Back at ya bud ;)
  9. mack4165
    mack4165 New Member
    put 9mm ply over floor screw down every ware then tile over
  10. GKU
    GKU New Member
    Nah , absolute MINIMUM 12mm ply , 9mm is not rigid enough
