Tiling on unsquare walls
Discussion in 'Tilers' Talk' started by jonniejoejonson, Aug 30, 2021.
  1. I have walls that need to be tiled, but they are not square to each other. They are plumb and level but are not square to each other. Does this cause a big problem when tiling (walls) or am I over thinking it?. thanks to any responders.
  2. CGN
    CGN Screwfix Select
    Just treat as normal. Only thing to consider, is if you’re doing a layout where you want to align floor tile grout lines with the walls, assuming you have tiles that would allow that.
