Tiling onto a mist coat- avoid?
Discussion in 'Tilers' Talk' started by LJdiy, Nov 9, 2018.
  1. chippie244
    chippie244 Super Member
    You liked his post :p
  2. CGN
    CGN Screwfix Select
    Tiled on the bits that they mist :D
  3. CGN
    CGN Screwfix Select
    Clumsy thumbs Chippie. :D
    chippie244 likes this.
  4. chippie244
    It's like BAS is back :confused:
  5. Aura noire
    Aura noire New Member
    Ok, your right I’m wrong.
    OP just crack on then.
  6. Jord86
    Jord86 Screwfix Select
    British Standards state a lot of things mate, but unfortunately we don't live in an ideal factory set world, there's a lot of grey areas you have to navigate and determine what will or won't work through pure experience, not from what a book tells you. Do you ever tile on plywood, use PVA or tile on top of tiles?
  7. CGN
    CGN Screwfix Select
    Im sure you mean well.
  8. Aura noire
    Not on Ply, nor do I use PVA.
  9. CGN
    CGN Screwfix Select
    BAS?
  10. longboat
    longboat Screwfix Select
    You can stand a 50 mm thick concrete slab on its end and it won't fall over.
    No adhesive, no grout, nothing but air on all sides.
    Drop a penny on it and it will still stay upright.
  11. Aura noire
    What are you talking about?!
  12. chippie244
    Ban All Sheds, still around on other forums apparently, made HA look quite reasonable.
    CGN likes this.
  13. chippie244
    You picked a fight ...
  14. Astramax
    Astramax Super Member
    A negative effect means that the tiles fall off!
  15. Aura noire
    No, don’t think I did.
    I was offering the OP advice based on their question and my 18 years experience tiling.
    I wasn’t counting on being trolled by a few stubborn members who think they know better.
    I have asked what your tiling experience is but have had no response.
    I tile on average 16sqm a day and have done for 18 years.
    I remove existing tiles from painted surfaces and mist coats weekly and in most cases the tiles will come off in sheets when broken into.
    If your happy giving advice to inexperienced people which could result in injury or worse then go ahead.
    Unfortunately I have worked for many builders with these kinds of attitudes and that’s why we are all tarred with the same brush.
    I think I will leave this forum to the likes of you and get on with my life producing quality work to a recommended standard guilt free.
  16. chippie244
    Crack on
    CGN likes this.
  17. CGN
    CGN Screwfix Select
    Do you have nights on the tiles?
    DIY womble likes this.
