Tips for replacing old bathroom
Discussion in 'Builders' Talk' started by Alexander Hepburn, Nov 22, 2018.
  1. Alexander Hepburn
    Alexander Hepburn New Member
    Hi
    Firstly I would like to apologise in advance if this has already been covered somewhere else, I am new to the forum
    I am away to start ripping out my old bathroom suite and putting in a new one.
    At the moment the bottom half of two walls are tiled and the shower area is also tiled. My plan is to tile the whole room.
    I have started removing some old tiles and as expected the plasterboard sheets underneath are coming away with the tiles. I was going to cut out the sections on plasterboard and replace the sections?
    Anybody got any better ideas or some tips etc for me doing this as it is my first time .
    Thanks
  2. LEH
    LEH Active Member
    You’d do better to take all the boards down and replace with tile backer boards e.g. jackoboard, wedi and the like. These are waterproof and can take heavy tiles. You just need to seal the joints and use the correct washers. You can use normal plasterboard, but you’ll need to tank it in the wet areas. This is cheaper though a bit more faff, the backer boards are a bit easier to work with but more expensive.
    John.h. and chippie244 like this.
  3. Alexander Hepburn
    I was going to use the green moisture resistant plasterboard. That is what is already in the bathroom. I assume this is good enough? Also can I tile straight on the green board? And what's the best adhesive to use? Completely new to all this but I am going to be selling the property soon so don't want to spend a fortune if i can help it.
    Thanks
  4. fostyrob
    fostyrob Active Member
    As mentioned above you can use plasterboard but newer and better solutions are now available which most other countries now use... the UK is fairly unique and stuck in it's ways.
    As it is is all coming down it would be a good time to get with the times.
    Just and example but there are lots of similar products around
    https://www.jameshardie.co.uk/product/hardiebacker/
  5. LEH
    LEH Active Member
    As cost is a concern, you can go with green plasterboard, but please do tank around the wet areas. Ardex or Mapei kits are good.
    Boards should be primed before tiling.
  6. Alexander Hepburn
    Thanks for the replies folks.
    I went and picked up some of the green moisture resistant plaster board today due to the cost difference.
    LEH you say I should tank the plasterboard in shower area still? And sorry for the probably silly question but what do I need to prime the boards with?
    Another couple things, do I need to fill the joins in the plaster if I am tiling over it? Also what's best adhesive and grout to use on this plaster? My tiles are ceramic 25x 40x 0.8cm and weigh 14kg m/2.
    Sorry for all the questions just don't want to miss anything or set myself up for a disaster lol.
  7. LEH
    LEH Active Member
    Yes I would tank the shower area. Moisture resistant plasterboard can take a bit of humidity but that’s about it.
    Something like mapei primer g, or you can use sbr. Be sure to follow the correct dilution from the instructions.
    Something like mapei keraflex maxi s1 would do you fine. It’s slow setting so good for diy. As long as it’s a bagged adhesive, that’s the main thing. The manufacturers will state what size tiles etc it is suitable for.
    Again the mapei ultracolor plus grout is fine, a lot of these products are available from the competitor... otherwise tile mountain have competitive prices, but factor in delivery costs.
  8. Mr Rusty
    Mr Rusty Well-Known Member
  9. Bathroom Remodeling Elements :
    Showers
    Showers have become more than a location and a way to clean your body quickly. High end showers are equipped with multiple spray heads, steam and benches for your comfort and enjoyment. They are equipped with anti scolding devices, temperature mixers and rain heads. The wet walls are cladded with exotic stone and mosaic tiles. The shower doors are made of frameless glass and non slip floor design for safer use while showering.
    Tubs
    Tubs continue to go through trending fixture development such as whirlpool soaker tubs and the most current trend of pedestal tubs with stand pole faucet fixtures. Tubs have also evolved to accommodate aging adults and disabled people. Walk-in tubs require less water, safer entry and exit and are available with whirlpool jets.
    Although showers have become the practical and preferred method of hygiene, no master bathroom is complete without some form of soaker tub. There is often much discussion about the exclusion of tubs from contemporary bathroom designs. The problem with this idea is that you are likely to sell your home one day and the lack of a tub could affect the sale.
    Flooring
    Stone or tile floors are the practical and most desirable of floor materials for a bathroom. This is due to the beauty and the practicality of a bathroom being a wet area. They are also materials that allow for making interesting design patterns in the floor. Owners should be mindful of the ever present risk of slip hazards when selecting materials. In addition the selection of floor materials will ultimately tie all the other features together in its global appearance.
    Lighting
    The use of wall sconces, low voltage cans and under cabinet lighting has added a great deal of drama to bathrooms. Special need lighting for applying make-up and accenting art work has also become expected in a master bathroom. Selecting lighting fixtures for women is often overlooked. Good direct wall mounted lighting is the best for applying make-up.
    Cabinets & Linen Storage
    The trend for upscale bathrooms is to use furniture pieces as vanity cabinets with stone tops. They provide a special rich and unique look in the bathroom. Providing a salon style sitting area and the use of shampoo bowls has become more desirable if there is sufficient space.
    Mirrors play a role in a well designed bathroom remodel. Incorporating mirrors into cabinetry or framing them to appear as art pieces adds a special elegance to the bathroom. Mirrors can also be used to make a smaller bathroom larger with the appropriate location.
    There is always a need for storage in a master bathroom. A linen closet is a must have to serve both the bedroom and bathroom areas. A space to safely store prescriptions and other types of bathroom necessities is both required and a convenience.
    Bathroom renovations can add both comfort and value to your home. The success of a bathroom remodeling lies in the process, professionals and details of executing a well planned project.
  10. goldenboy
    goldenboy Well-Known Member
    I would absolutely have used backer boards.
    By the time you factor in tanking the cist difference isnt going to be much at all.
  11. eve fitzsimmons
    eve fitzsimmons New Member
    For me I went with the London bath co. Great firm to deal with and service, which is key for me. They did all the hard work I just told them the design I liked and it was very reasonable. https://www.thelondonbathco.co.uk/
  12. goldenboy
    I used them. They were terrible. Just awful.
    They used sheets of a pork based luncheon meat to line the walls.
    Cal_0 likes this.
