Hi. First post.. I purchased this pressure washer (766KH) on the weekend and have to say it feels very sturdy and is on par with my now tired yellow one, but it wont work on the full power setting, it just keeps cutting out. We don't have low water pressure, and the washer is plugged into a 13 amp socket. It works a treat on the eco setting, but I need a pressure washer with the 150 bar. Titan do not have any technical depts or helplines to talk to either. Now, I could just take it back if its faulty and get a replacement but screwfix are out of stock everywhere and the obvious places for similar ones are also out of stock. So my question is, are there any obvious things to try in the event its something I am doing wrong, or could try differently. or, has anyone else got one and experienced the same issue. Thanks in advance.
Hi. I did try this and no different. They appeared back in stock again so replaced it and the new one works fine so it was faulty. Cheers though.
Hi. Assuming you have tried the obvious like ensuring the hose is fully unwound (not sure you actually need to do this), if possible trying another tap to check water pressure, ensuring your plugged directly into a wall socket ie not an extension lead, then it might be faulty. Mine was, I replaced it and the new one worked fine.
