Titan 18v cordless drill tti699com
Discussion in 'Screwfix Live' started by David p Matthews, Sep 25, 2020.
  1. David p Matthews
    David p Matthews New Member
    Brought this Titan 18v cordless comi tti699comi drill 18 months to two years ago from Screwfix, the battery charger seems to stopped working tried to find another it has come really difficult to find one it seems screwfix do not sell this item no more, is there anything else I could use seems a waist to replace it.
  2. Teki
    Teki Screwfix Select
    COould you post a photo of the charger, there may be similar ones you can use. How competent are you with electrics? Have you opened up the charger?
  3. quasar9
    quasar9 Screwfix Select
    As Teki says “ there may be similar ones”. I had a Black & Decker drill whose charger failed but could not get a replacement. In the end, I bought a Draper charger which had similar electrical characteristics but a totally different physical design (battery contacts etc) and effectively transplanted the electronics. It worked for a few years till the battery stopped holding a charge !
