Titan litre saw TTB598MSW 210mm Head lift
Discussion in 'Screwfix' started by Richard Hancock, Nov 25, 2017.
  1. Richard Hancock
    Richard Hancock New Member
    1. I have recently bought a Titan TTB598MSW 210mm Single-Bevel Sliding Mitre Saw. I unlocked the pin allowing mitre head to lift up and down. Pulled it up, but cannot descend the head back to it's original position. Stops halfway down. Am I missing something.
  2. KIAB
    KIAB Super Member
    It as a trenching facility?
    Right hand side you have the button to lock head, just above you have height adjustment scre, check this.
  3. Richard Hancock
    No wrenching facility. Height adjustment screw set for normal cutting blade is 100mm above base when it stops, above anything ready for cutting.
  4. Richard Hancock
    No trenching facility
  5. WillyEckerslike
    Has the head locking pin sprung back in? It might require a half turn to keep it retracted.
  6. wiggy
    wiggy Screwfix Select
    It does have trenching facility, depth stop, whatever, push it back up
  7. Richard Hancock
    Depth stop screwed right up
  8. Richard Hancock
    Took it out when I released the head
  9. wiggy
    page 4 of the instruction manual
    no 22
  10. WillyEckerslike
    Sorry to ask this but....
    Are you using the thumb lever to retract the blade guard as you lower the head?
  11. Richard Hancock
    Yes I am, but the blade and guard are way above fouling anything
  12. Richard Hancock
    Yes. Wound up. The head is still angled at about 20 degrees when it will go no further.
  13. WillyEckerslike
    They don't foul anything, there's an interlock which prevents the head from lowering without the thumb lever depressed at which point the guard will retract as the head is lowered. It sounds like the guard release is caught on something.
  14. WillyEckerslike
    I'm not familiar with this saw but surely you can't take the release locking pin out? Isn't it spring loaded and retained somehow?
  15. Richard Hancock
    It's purely a stop.No Spring in the pin. The head rotation mechanism isn't linked to the pin.
  16. WillyEckerslike
    I think we're talking at cross purposes. The pin you removed to unlock the head is the one I'm referring to.
