Titan SF10N1 10" Table Saw 230V
Discussion in 'Carpenters' Talk' started by roadster2, Jun 14, 2008.
  1. roadster2
    roadster2 New Member
    Just assembled the above saw (What a pain!).
    I assume that the blade/motor is adjustable in some way? The saw blade is currently sitting 3 or 4 degrees away from true and rubs against the side of the table slot.
    The mechanism that locks the guide bar onto the table is also missing. What is policy regarding missing bits? Do they send you the missing item or replace the whole thing? No point messing about if it has to be replaced anyway...........
  2. evo nut
    evo nut New Member
    they normally replace the whole this especially if you say something isn't right
    trouble is TITAN is CHEAP!!
    EVO NUT
  3. roadster2
    Cheap? A bit like me then!
    The first review on the Screwfix site mentions something about being able to set up the motor / blade but there is nothing in the instructions that I can see and on first inspection it's not obvious how to do it.
