Titan strimmer/hedge trimmer acting up
Discussion in 'Landscaping and Outdoors' started by furious_customer, Jun 13, 2018.
  1. furious_customer
    furious_customer Active Member
    I have been using the titan 2-in-1 multi tool with a pruner attachment to reduce my beech hedge.
    It is starting to act up (within the 12 month warranty thankfully) - it seems to idle fine, and work at low revs ok, but if I pull the throttle lever back full then it seems to stutter and lose all power.
    Any ideas what could be wrong?
  2. KIAB
    KIAB Well-Known Member
    Possible fuel starvation, is there a filter, look inside fuel tank, you might see a fuel suction pipe,& on the end is a filter.
    Had a friend had similar problem with a strimmer,took me ages to find the fault, the fuel suction pipe in fuel tank had a small split in it,so at tickover strimmer ok, but at revs the petrol never got further than the split & trickled back into tank.
    See below,black pipe was kinked in tank & it eventually got a small split.
    [​IMG]
    ramseyman likes this.
  3. ramseyman
    ramseyman Active Member
    You may find you have a low speed screw marked L on the carb. Try turning that clockwise slightly, say 10 minutes on a clock and see if that improves the situation. May need a bit more. If it idles too fast so that blades keep running back off the idle speed screw slightly.
