Try a Boss adapter. I bought one today from B&Q for £1.88. Push it into the 57mm id of the saw. The 32mm opening will accept the suction hose tube of my Titan vac or my Vax. Other sizes are available: 40mm; 50mm. A cheap solution that works.
Hi, yeah I have come across this minor problem, I overcame it by using duct tape, firstly I covered the adapter front with a reasonable amount of tape, I then put a cross slit in the tape just big enough to take the vacuum cleaner's pipe making sure that the tape cuts were sticking to the pipe, then I used more tape to secure the pipe into the tape (if you see what I mean) and it works, one minor drawback was the vacuum cleaner I used only has a small dust container on it, it is the one I use for cleaning the car and so I have to keep my eye on the fill rate, another small problem is that I have to keep taking it apart when I need to clean the car
Hi all just registered for this, I just solved this bycutting a lidl orange juice bottle down to about 5” from the neck then placing this over thetable saw plastic outlet, I put the nozzle rubbery adaptor that came with my guild ( screwfix) wet n dry vac into the bottles cap end and withtge vac running just played gently hot air from hot air gun over the overlapping cut part of the bottle wereupon it shrank around the neck forming a perfect (and see thru) adaptor which allows for both the top hose and the under the saw area Literally took seconds- honest!
