Toilet cistern not filling
Discussion in 'Plumbers' Talk' started by Davut, May 22, 2020 at 11:52 AM.
  1. Davut
    Davut New Member
    Our bathroom's toilet is fed from the wash basin's cold supply. The toilet cistern often does not fill after flushing, but I discovered that if I turn the cold tap on it does. Any thoughts as to what is going on here?
  2. terrymac
    terrymac Screwfix Select
    Probably a partial blockage within the float valve. Post some pics of the set up inside the cistern.
  3. Davut
    Davut New Member
    Been trying to add a picture, but all I keep getting is either "file too large" or "error occurred". Have you an email or other way I can get the picture to you?
  4. terrymac
    Reduce the file size.
  5. Davut
    Davut New Member
    Ok I hope you can see this
  6. terrymac
    The lever ,just below the red top of the valve,is affixed to a large black float.
    Is the lever and float moving freely ? Try lightly pulling up and down the lever. If it moves freely ,there is a problem within the valve. You can try to strip it and renew parts , or just fit a new valve complete ( cost around 12 quid).
  7. Davut
    Davut New Member
    Seems to have worked. I just took it off and put it on again. Cheers
  8. terrymac
    Took what off ,and on again ????
