I am planning to, but the garden has a fair bit more work in it. I want to raise the lawn, build a timber shed/workshop at the back (insulated, cedar cladded etc.) pave down the middle, build raised beds both sides... Quite a lot to get on with before I start re-seeding!
Toilet Extractor: I had temporarily hooked up some flexible ducting, had been in for about six weeks. I wanted it in rigid. Used round for the run up to the extractor, and rectangular after the extractor. Rectangular comes down from within the stud wall above. Extractor is from Screwfix, is a vent-axia (https://www.screwfix.com/p/vent-axia-acm100t-21w-in-line-bathroom-extractor-fan/53730) It was one of the few I could find that would work with the length of ducting. It can shift a serious amount of air, although I have it on the lowest setting at the moment. Rectangular runs out to front garden. I used a Wickes air brick and adaptor for this, so it didn't look naff. http://www.wickes.co.uk/Manrose-PVC-Air-Brick-Adaptor---White-110mm/p/168821 http://www.wickes.co.uk/Manrose-Slimline-PVC-Air-Brick---Brown/p/167623 Used a combination of the disc cutter, angle grinder and SDS chisel for this. I have since strapped in all the ducting. At some point I'll get around to putting Celotex in between the joists too...
You should never use bonding on outside walls especially 9" ones. The reason is Bonding attracts water/moisture to itself,that is why it is better avoided in some enviroments. You may not have used it on an outside wall, but I personally would not have used it in a toilet area.
Left this thread hanging too. Here's the finished project! In progress of fitting sink and rad: Sink and toilet came from Victoria plumb, radiator from Screwfix (the smallest Kudox one) and bathroom accessories from B&Q. New 25mm Ply floor laid: Sink waste. Comes down inside wall and drops into a strap boss on the rest bend. Painting in process: Rear of toilet - the wall build up is 6" studs, ply, plasterboard and plaster finish. Other side (in cupboard) has a sheet of ply, which can be removed for servicing. Stub stack incorporated here, and due to this, I needed to make up an offset flush pipe, shown in the lower photo. And...the finished result, following lino floor, skirting and fittings/accessories installation. (Toilet roll holder not installed yet....some cable ties will do!)
Well that's a first, a strap on boss on a rest bend. Would have used flexible hose on water connection to cistern, & have isolation valves on basin feeds
Hey Kiab! How are you keeping? The boss was a first for me too, but it sealed first time and is still good a year on. I didn't have much room or fall to install it on a straight length of pipe, so tried it there. On isolation, the cistern is connected to the lower of the two yellow lever valves. The basin tap can be isolated below, in the cellar: Buteline's pipe has crimp on 1/2 female threads, good for stuff like cisterns and isolation valves ect.
Doing my parents downstairs toilet. Will try and upload some pictures. Soo difficult working in a confined space.
