Toilet
Discussion in 'Plumbers' Talk' started by lady_new_2_diy, Jun 19, 2020.
  1. Thanks would it be possible to bring forward with this type of fitting (link to my post above with photo for convenience) #3
  2. just pumps
    just pumps Screwfix Select
    Ma
    Marginally but it won't stop a house sale.
  3. DIYDave.
    DIYDave. Screwfix Select
    Agree the seat can be adjusted side to side but not so sure with that type hinge that there’s any front to back adjustment possible
    Of course, I’m happy to be wrong on this point
    With the round hinge plates you either rotate them to bring seat back and forth or they have a choice of fixing holes for metal hinge
    Don’t think there’s this luxury with this hinge and yes, seat does look a little small for the bowl
  4. I'll email the plumber on Monday with photos and say its too small and misaligned.
    Thanks, hope he has time to change it. I haven't been invoice for it yet, feel like young plumber rushed the job, he even admitted to rushing it. That's why I put so many problems on this page regarding wonky pipe, not deburring etc.
  5. DIYDave.
    Some toilets can be tricky to match up a good fitting seat to and especially at a certain price point, depends on the shape and size of the bowl
    Other toilets will fit the first seat that comes off the shelf
    Some ‘D’ shaped toilets are really difficult to match a seat to and often have to buy an over priced manufacturers seat as nothing else fits
    Recently helped out a friend of my mums by sourcing and fitting a seat for her but took hours of looking and trying several seats before finding one that fitted at an ok price for her. Was recommended a seat by Twyfords (I think) but was over £100 for a white plastic seat and for this little old lady, that was too much
    Local independent bathroom shop came up trumps in the end for a little over £30
    Of course, I didn’t add a penny, my good deed for the day :)
    The rubber feet should at least be supporting the lower seat on the rim of the bowl so when you sit, your weight is supported across the seat by the rim and the seat doesn’t bend
    If the seat is a poor fit, the feet may not be on the rim or only just
    Anyway, don’t worry too much and hopefully the guy will swap the seat without an issue
    As to influencing the sale of your house ...... you gotta be kidding right ? :confused:
    Anyway..... I can’t talk about loo seats all night long, my wife is missing me :)
    lady_new_2_diy likes this.
  6. Thanks for your reply
    Yeah, the rubbers don't span the bowl, they don't reach the outside of it, and hang over the inside of the bowl.
    I would rather the seat doesn't bend or even break.
  7. Astramax
    Astramax Screwfix Select
    I wouldn't worry as after changing the door locks the next thing is replacing the toilet seat when new people move house.
    lady_new_2_diy and The Teach like this.
  8. The Teach
    The Teach Screwfix Select
    For a start it looks like a bottom fixing wc seat,if it is bottom fixing could try loosening the wing nut type of nuts and carefully pull the seat forward. If that does not work remove the seat and look to see if there is alternative bolt fixing slots/holes in the toilet seat bracket.
    Line up the seat so its central to the wc pan,photo shows a hint its orf center.
    The seat buffers need to uniformly rest on the china rim,if they dont maybe there is a compatibility issue.
    Wc seats,why so difficult :D
  9. Hi an update, emailed plumber with pics sent on here, he will adjust. He said it is the correct seat, but I think its too small.
  10. Astramax
    Seats can be adjusted forward and backwards so that's what the plumber will do. :)
  11. Thanks, will report back if I have more info.
  12. Timbo66
    Timbo66 Active Member
    I think you'll find that those hinge bases can be swapped to the opposite sides, moving the seat forward as a result.
  13. Thanks, hope plumber knows this, he has 35 yrs experience so I am sure he will.
  14. Forum been down so I thought I would send a picture of the toilet now that the plumber has moved it forward. Comments welcome please. IMG_20200628_192217760.jpg
  15. masterdiy
    masterdiy Screwfix Select
    Its a pity you didn't replace £5 worth of new lino, & run a coat of paint over the walls.
    Now that would put me off more than a doggy looking loo seat.
    Ps. The loo seat still looks out of line.
  16. Yeah I thought that too, the plumber brought a new loo seat with him but decided to use the same one.He is an accredited plumber, not from checkatrade etc, he has proper accreditations from plumbing trade body, it was his employee who fitted the loo and him who straightened it. He lives about 30 miles away do you think I should tell him or is it easy to put back in line? I don't wanna have to pay for petrol.
  17. DIYDave.
  18. Astramax
    He should of gone to Specsavers! :D
    masterdiy likes this.
  19. Squashrobinson
    Squashrobinson Active Member
    Fascinating.
    fff likes this.
  20. fff
    fff Member
    There is no way I would buy a house with a toilet seat like that.
