Toms top tips from than award :-)
Discussion in 'Plumbers' Talk' started by Copper Dragon, Feb 21, 2010.
  1. G Brown.
    G Brown. New Member
    I popped a ballon once, christ it made me jump.
  2. Copper Dragon
    Copper Dragon New Member
    I popped my load once made me go yer ;)
  3. G Brown.
    G Brown. New Member
    yeah but can you remember your 1st *
    [Edited by: admin]
  4. Nirdam
    Nirdam New Member
    Have a relative who tests all his fabricated pipe sections with air. Worked for him for a while.
    He builds road oil tankers.
    When pressurised to about 100 psi we just took them to a water tank, immersed them, marked leaks and re welded.
  5. Nirdam
    Nirdam New Member
    Worked for a fabrication company who makes storage tanks for filling stations also.
    They pressurised the huge tanks with air also.
    Wonder what they would say if this muppet onetap suggested filling it with water?
  6. natrosol
    natrosol New Member
    I,ve typed up three quotes tonight,polished off a bottle of cheap red plonk,come back on here and you lot are still going,cleared some blocked stainless steel pipework last night at work with compressed air (stearic fatty acids back into tank),you should have heard it go, nearly blew the lid off :)
  7. imran_
    imran_ New Member
    Test with air if you want - your PLI won't cover it and the HSE will be all over you if anything does go wrong!
    Blow up a balloon, then either pop it or let it go and watch it fly across the room. Both are rapid releases of energy from a small amount of slightly compressed air. Now multiply by a big factor in your pipework.......
    There's plenty of vids on youtube that show compressed air guns/rockets, etc. Quite a few show objects going through 2 x 18mm ply, so a bit of plasterboard and leg will be no problem ;)
  8. Teuchter
    Teuchter New Member
    There is absolutely nothing wrong with testing with air.
    As long as it passes the test.
  9. imran_
    imran_ New Member
    Well if you're sure its going to pass its pointless testing it in the first place ;)
  10. Teuchter
    Teuchter New Member
    And if it fails you won't be there to tell the tale.
  11. Itandje
    Itandje New Member
    You need to lay off those Stephen King horror stories.
    Do you do a risk assesment whenever you top up your tyres?
  12. imran_
    imran_ New Member
    1. Tyres are designed to be filled with air and are designed to fail in a non-explosive way (blowout only occurs when the tyre is run over something that creates a massive hole)
    2. Copper and plastic pipes and fittings conforming to EN-1254 are not designed for compressed air
    It is as simple as that!
  13. palavaman
    palavaman Well-Known Member
    here we go again. i'v had a hard day at work & need some amusement, why dont u lot let this drop? onetap has packed his bags. he aint reading this.
    says he'll visit now & again though:^O
  14. Guest
  15. Itandje
    Itandje New Member
    Yeah but if you forget itaps scare tactics you're only talking about 2 0r 3 bar with a footpump. Copper and plastic pipe and fittings would never shatter, and god knows what pressure you'd need to shatter something like a rad valve. The only danger I can see is a flying endcap, so as long as a bit of common sense is used what's the problem? According to soft arze teuchter,it's a deadly exercise if it goes wrong. Perhaps one in a million someone might get hurt. But a woman got killed yesterday walking to work past a grasscutter, it threw up a piece of pipe hidden in the grass, hit her on the head and killed her. Shall we ban lawnmowers?
  16. palavaman
    no dont ban lawnmowers, just ban grass cutters. its the grass cutter that engineered her demise.
  17. GKU
    GKU New Member
    YAWWWNNN !!!!! :O :O - Seriously guys , this is getting boring beyond comprehension , dear oh dear , oh dear , some of yas needs to read through this whole saga again , its sad , sad , sad , please kill it off , argue the toss about something else thats of no interest for a while , just change the sorry , sad record PLEASE :O :O
  18. spongeblob
    spongeblob New Member
    Fookin hell, your about early this mornin GKU. Are you up on the Seringetti eating grass with all your wildebeest mates. :^O :^O ;)
  19. GKU
    GKU New Member
    ;) GNUUUUUU
  20. Dick Puller
    Dick Puller New Member
    I'm with you mate, it's getting boring & Tom aint gonna remove the vid anyway and quite rightly so. I mean lets face it, Tuechter & 1tap are clearly not the full Shilling!!
