Tool for levelling raised splits across planks
Discussion in 'Carpenters' Talk' started by a name, Jul 29, 2021.
  1. a name
    a name New Member
    Can anyone suggest a tool for reducing raised splits in the planks of a wooden building without too much damage to the surrounding paintwork please. The splits are only 1.5 inches across the planks (not along) and raised by less than 1/4 inch on one side of the plank like a twist. Knuckles prevent using a file. Takes forever with small sanding block. Perhaps an angle grinder of some kind?
  2. teabreak
    teabreak Screwfix Select
    Can you post a picture of the situation?
  3. a name
    a name New Member
  4. a name
    a name New Member
    Hopefully pic will be there now.
    I plan to fill the split after leveling the raised edge.
  5. I-Man
    I-Man Screwfix Select
    Block plane / electric sander
  6. teabreak
    I would hit it with a belt sander, I suspect it will open up again though as the knot dries out over time, a brown paintable frame sealer which has a bit of flex might be best.
  7. a name
    a name New Member
    Thanks guys.
