Tool to nip up weepy 28mm valve
Discussion in 'Plumbers' Talk' started by Jimbo, Jun 14, 2021.
  1. Jimbo
    Jimbo Screwfix Select
    Have a valve behind a unit that needs nipping up. Problem is access - I can get a pair of short wide jaw adjustables on it fine, but can’t get enough leverage to move the nuts.
    Any tools out there that can help?
  2. kiaora
    kiaora Screwfix Select
    Hi
    Not sure if it helps, but if 28mm fitting needs ‘nipping up’, it may be better to loosen off the nut and add some paste/boss white, to the olive?
    good luck
    Peter
    RobJamesHeating likes this.
