Transfer any file from your phone to PC, and vice versa using WhatsApp.
Discussion in 'Just Talk' started by Dot99, Aug 8, 2018.
  1. Dot99
    Dot99 Member
    1. Open WhatsApp and select new group.
    2. Give your group a title.(mine is called file transfer).
    3. Add a ( temporary) person to this group(wife, buddy etc) and create the group.
    4. You are the admin of this group so now remove that temporary person. You should be the only person in the group now.
    5. Now, for example you want to transfer a image to your computer. Select the image and share it with your group.
    6. On your computer (with it switched on of course). Go to the whatsapp website and click on WhatsApp Web and follow the 2 instructions.
    Your phone WhatsApp will now be visible on your computer. Find your group and the image will be there.
    Remember to logout once done.
    Hope this helps with with data transfer. Once setup is easy.
  2. Wayners
    Wayners Well-Known Member
    Just use Dropbox. Free version is good enough but I'll look at the what's app option out of interest myself. Sounds interesting
