Travertine unsealed tiles
hgbmkh
New Member
i have sealed travertine wall tiles 100x100 with two coats of sealer, then grouted and wiped down, but when dryed out i have a white grout film on the tiles, is there anything that will clean the tiles and do i need to seal the tiles after grouting
The dried white film can usually be buffed off with an old dry rag or old towel, seal again once all the film is off the surface.
Jason
if you have sealed ur tiles with impregnating sealer u should be able to wipe them down with a damp cloth, leave it to dry and then polish with a dry cloth unless u used a ready made grout in which case you will have to wash them several times to remove the film.
you will not to reseal them again if you have sealed them twice if you do ur grout will dry all patchy.
Hope this helps ,,,,
Back
Top
