Treated Post - Please help
Discussion in 'Carpenters' Talk' started by Kas228, Apr 15, 2019.
  1. Kas228
    Kas228 Member
    DD6C3D8B-5D2B-4E06-9DE3-3A75A7E79F19.jpeg [​IMG] Suggested to post here rather than Builders forum.
    Hi , can anyone suggest best way to keep this treated post from rotting. As you can see it’s opened up and probably looks worse in photo than it is. it’s sound at present but what’s best way to preserve it. Fill it? Leave it open and treat regularly? What’s best to keep it from rotting just want your ideas. Thanks
  2. JustPhil
    JustPhil Active Member
    Take it back and ask for another. That’s a bark inclusion I think, not solid timber.
  3. Kas228
    Kas228 Member
    Too late for that it’s already in situ. Hoping for remedies to keep it from rotting for a few years
  4. longboat
    longboat Well-Known Member
    The base of the post thats in contact with the ground will rot way before that little section does.
    I wouldn't worry about it.
  5. Kas228
    Kas228 Member
    Ok thanks, but just to be on the safe side, should I liberally put wood preserver inside just in case. I presume it won’t do any harm?
  6. Astramax
    Astramax Well-Known Member
    Yes it won't do any harm. ;)
