Tree root in the way of new slabs!
Discussion in 'Landscaping and Outdoors' started by JamieFarmer, May 11, 2021.
  1. JamieFarmer
    JamieFarmer Member
    Morning all.
    I'm a DIY'er here, so excuse the lack of knowledge and experience! I am planning to lay new slabs in 2 corners of my garden that were previously paved with random bricks and slabs of different sizes with some sandstone slabs, but when I pulled up the old slabs and started to dig the ground I came across a big tree root in the corner of one of the areas that is close to the surface and is not going anywhere! What are my options here to get around this? The only thing I can think of is to raise the ground up and level on top of it, which wasn't the original plan, but that root is there to stay! Hopefully you can see it in the pictures attached. The size of the are itself isn't huge and will be used mainly to store the kids toys etc. on, so is a sub-base needed for it?
    Cheers all.
  2. furious_customer
    furious_customer Screwfix Select
  3. Kas228
    Kas228 Screwfix Select
    How far away is the tree it’s attached to?
    How much lower than the root are you needing to go?
  4. JamieFarmer
    JamieFarmer Member
    Well, I was planning on going almost level with the lawn. I think the tree is actually on the other side of the fence in my neighbours garden!
  5. Kas228
    How big is the tree?
  6. JamieFarmer
    JamieFarmer Member
  7. JamieFarmer
    JamieFarmer Member
    Not massive, and to be honest I don't even think it's still alive!
  8. Kas228
    Need to know how big the tree is and how close to the base of the tree the root is really
  9. JamieFarmer
    JamieFarmer Member
    I'm guessing it's the tree to the right of the fence in the picture.
  10. FlyByNight
    FlyByNight Screwfix Select
    Obviously the neighbours have decided they do not want a large tree in the corner.
    Dig down by the gravel board and cut away as close as possible, then dig out the next couple of feet. Back fill and compact.
  11. goldwise
    goldwise Active Member
    I use a jig-saw to remove tree roots under paving sometimes. Dig around and under the root then cut it out. Have also used a hammer and chisel.
  12. Kas228
    Given picture, personally I would take saw through root and take out or chip away at it with an axe to give me required depth
  13. JamieFarmer
    JamieFarmer Member
    Ok, thanks all.
  14. FlyByNight
    And if you don't have a suitable saw or axe, then a razor sharp shovel or spade will slice through it.
    JamieFarmer likes this.
  15. JamieFarmer
    JamieFarmer Member
    Nice one, that's tonight's plans sorted then!!
  16. cleggie
    cleggie Active Member
    dig down at side of graqvel board and use a reciprocal saw to cut thru roots.Can hire one if needed for day.Or even a small chain saw if confident enough and use safely
  17. JamieFarmer
    JamieFarmer Member
    So last night's activity involved a lot of digging. Now just need need to somehow cut and remove the root!
  18. FlyByNight
    Do NOT use a chain saw - you will ruin the chain and throw up sharp stones everywhere.
    If you have an axe - easy.
    If not, get your spade and if you have a sharpening stone or kitchen steel work on the edge to get it nice and sharp - it should not take much. Then, wearing gloves, loosely grip the shaft with one hand and grip the handle with teh other. Holding it 2feet/600mm above the root pushing is down hard and fast - it will cut in. Repeat and repeat - you will finally cut through at each end.
  19. JamieFarmer
    JamieFarmer Member
    Borrowing an axe and giving that a go. It's not too thick so hopefully won't take much.
  20. FlyByNight
    With an axe look to make a 60 degree wedge shape. A couple of chops from the left, then right then left ... take debris out and keep going. With a sharp axe - 15 minutes to sort that root.
