Trend diamond credit card sharpener
Discussion in 'Tool Talk' started by StuG, Oct 8, 2021.
  1. StuG
    StuG New Member
    Just purchased the diamond credit card sharpener from screwfix, noticed it hasn't got which grit engraved on each side 300 or 600, how do you tell, feeling with your hands isn't really obvious
  2. I-Man
    I-Man Screwfix Select
    magnifying glass and lots of patience?
  3. rogerk101
    rogerk101 Screwfix Select
    What on earth is a credit card sharpener?
  4. GS63
    GS63 Member
    Try drawing a fingernail across it. I find it easy enough to tell visually if you hold it under a good light.
  5. WillyEckerslike
    It's so that you can use a credit card for scraping silicone Roger. It puts a better edge on the card.
    Actually it's a diamond embedded metal sharpening stone the same size as a credit card.
    BillyBobToo and rogerk101 like this.
